Author: Subject: Two methods of security
Dave Bailey
posted on 5/2/08 at 10:31 PM Reply With Quote
Hi! to make my steering column less cluttered I am thinking of removing the idnition swtich from the column and fitting a switch and push button into the dash. Problem is that the column lock will go with it. I understand you need two security devices on the car.. Has anyone else done this and what two devices have they used for SVA?
thanks
Dave B
bigrich
posted on 5/2/08 at 10:39 PM Reply With Quote
my column has been machined to remove the switch gear and ignition lock etc, so i have an ignition switch on the dash and an FIA type switch under the bonnet, I have used this method on both cars i have built and SVA'd
blakep82
posted on 5/2/08 at 10:41 PM Reply With Quote
electronic immobiliser would do te trick too, either the type wit a key ring you plug in, or transponder type
________________________
liam.mccaffrey
posted on 5/2/08 at 11:38 PM Reply With Quote
big rich, it that the base of a computer joystick on your dash?
Build Blog
Build Photo Album
RazMan
posted on 6/2/08 at 02:04 AM Reply With Quote
A simple battery isolation switch can be one of the security methods.
Raz
Miks15
posted on 6/2/08 at 07:27 AM Reply With Quote
can you not just leave the the swithc on the column then change post sva? just a thought
posted on 6/2/08 at 10:41 AM Reply With Quote
A key switch on the dashboard and a battery isolator switch did it for me.
Personally I think QR steering wheels should also count but it appears usually they cause more problem than they get rid of....
bigrich
posted on 6/2/08 at 10:52 AM Reply With Quote
its just a sierra column with the the top machined smooth the remove the switch mounts etc and a set of zx10r bike clocks
It also has a Q/D steering wheel which was on at SVA without any problems
[Edited on 6/2/08 by bigrich]
posted on 6/2/08 at 12:00 PM Reply With Quote
Originally posted by Miks15
can you not just leave the the switch on the column then change post sva? just a thought
It has to immobilise the engine as well as lock the steering if you use the column switchgear, if you can lock the column with the engine running it is a bit dangerous. It's probably more of a wiring job than you want to do twice as well.
DarrenW
posted on 7/2/08 at 01:18 PM Reply With Quote
My column is same as Rich's. I have key switch and push button, and an ignition immobiliser (cat 2 type device). Passed no problem.
tks
posted on 7/2/08 at 02:08 PM Reply With Quote
what for is the sensor on the brake pedal???
i see the stop for it but what for is the second thingy
Tks
Dave Bailey
posted on 10/2/08 at 04:58 PM Reply With Quote
O.k. I have spent the day with the old die grinder removing the ignition switch and all other bits! So the question is now what options do I have for the indicator and horn switches for SVA? How have people mounted them In the dash or on the column?
Big Rich what did you do?
thanks
Dave B
