Dave Bailey
posted on 17/2/08 at 08:47 PM |
FIA Battery Isolator switch
Where can these be mounted to get through SVA???? Wanted to put it on the Dash but this I suspect is not acceptable also I have to mount an ignition
switch. I can get a switch with the correct radius but when the key is in it it will fail. Again where have people mounted them?
thanks
Dave Bailey
bigrich
posted on 17/2/08 at 08:50 PM |
if you really want them both on the dash then fit them inside the 127mm exempt area around the steering wheel
I have an ignition switch on the R/h side of the dash and a cut off switch in the engine bay on the scuttle bulkhead panel
nitram38
posted on 17/2/08 at 08:51 PM |
Within 127mm radius from the outer edge of your steering wheel, is exempt from the projections rule.
Somewhere there will be ok.
minitici
posted on 17/2/08 at 09:29 PM |
You could always have the cut off switch under the bonnet and connect it to a cable pull on the dash. I've done this on a few hillclimb cars.
