posted on 28/10/03 at 12:36 PM |
catalytic converter dates
Can anyone tell me what the manufacturing cut-off date is for engines to need a catalytic converter?
Nick
StuartA
posted on 28/10/03 at 12:56 PM |
I think it is not the case of needing a cat, but more to do with stringent emissions tests. After a specific manufacture date (1st August 97?) engines
are tested to more stringent standard. You are unlikely to pass this test without a cat, although I believe it can be done.
Sorry if this isn't much help. Do a search for emissions and you might find the answer you are after.
timf
posted on 28/10/03 at 01:00 PM |
In simple terms, the emissions must meet those applicable when the engine was new. The SVA test draws the line at August 1995.
If the engine is younger (ie post ’95) it will be tested to ensure it produces less than 0.5% CO and 200ppm HC, whereas older engines are allowed 3.5%
and 1200ppm HC
StuartA
posted on 28/10/03 at 01:06 PM |
Whoops... August '95 not '97. Didn't think that sounded quite right!
posted on 28/10/03 at 01:40 PM |
So is 01/08/95 the cut-off date?
Nick
timf
posted on 28/10/03 at 01:51 PM |
1-08-95 = august 95 so yes it is the cut off date
Spyderman
posted on 29/10/03 at 12:43 AM |
I thought it also depended on whether the original engine had a cat fitted to it in it's donor.
I know that the K series engines of around 1991 had both non and cat exhausts. Single point injection cars did not have cat, but multipoint injection
cars did.
Not a great deal of use though.
Spyderman
zetec
posted on 29/10/03 at 02:57 PM |
No at the moment it is "95 cut off date for the engine and not the donor. The rules don't seem to tie kit cars down too much and
don't cover engines being removed from the original cars.
timf
posted on 29/10/03 at 03:51 PM |
they go by the engine normally to get below the emmisions required for post aug 95 you will need a cat if you can get below without then you
don't need the cat but you carn't normally achive this
