Author: Subject: Adjustable M/C pushrods???
posted on 29/10/03 at 05:09 PM Reply With Quote
I'm thinking of making an adjustable master cylinder pushrod - PICTURE HERE.
Does anyone know if this will be a problem for SVA?
Any other comments welcome as well!
Nick
Mk-Ninja
posted on 29/10/03 at 05:18 PM Reply With Quote
You could make me one while your doing
I'm sure I've got one, just don't know where I've put it
rell
posted on 29/10/03 at 05:45 PM Reply With Quote
i think you should be ok as long as it bracks ok
posted on 29/10/03 at 05:47 PM Reply With Quote
rell,
I hope you mean "as long as the car brakes OK" and not "as long as the rod breaks OK"
rgds,
James
posted on 29/10/03 at 05:56 PM Reply With Quote
Nick
Not saying you've not thought of it yourself but that's identical to the one I've used from a MK2 Nissan Micra- might save you some effort!
I cut the pushrod off just after the threaded bit and welded it to the pushrod from the Sierra. The Sierra one is adjustable at the m/c end so you end up with adjustability in both position and length of rod.
James
posted on 29/10/03 at 07:39 PM Reply With Quote
That's how I did mine and it passed 3 years ago. I don't think the tester even looked at the mechanism even though it was open to view.
yours, Pete.
posted on 30/10/03 at 10:44 AM Reply With Quote
Cheers guys!
James - Hadn't thought of making it from other parts, but it's not a bad idea at all.
Nick
CairB
posted on 31/10/03 at 08:54 AM Reply With Quote
Nick,
As in the other thread, I used one from Merlin that only needed a bit cutting off the end and rounding. IMHO, for ease mind and at SVA I feel that it would be better not to fabricate this important part.
Colin
