vinnievector
posted on 29/2/08 at 02:21 PM |
might have to change
some advice with the braking system ,
Is it ok to fit a single curciut brake system for the SVA or do i have to go with the duel one cylinder two out lets ,or twin cylinders with balance
bar .
tegwin
posted on 29/2/08 at 02:25 PM |
It doesnt matter how you do it, but you have to have a split system so that if one hydraulic system fails there is still braking to two wheels
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 29/2/08 at 02:27 PM |
having tried the bias bar I'd not do it again
posted on 29/2/08 at 02:36 PM |
because..............?
vinnievector
posted on 29/2/08 at 02:45 PM |
@ the moment i have a single girling cylinder with one outlet which gose to a tee piece then off to the front and rear brakes then on each axel point
tees off to the wheels .
Is tis acceptable or should it be a dual cylinder
Mr Whippy
posted on 29/2/08 at 02:47 PM |
Well lets see, it was a horrible rattely affair and a nightmare to adjust the bias in that tiny foot wheel, was very expensive for what was really a
couple of old landys master cylinders and a bit of tube, oh and one cheap ball race. I’d have given it a year before it all started to go rusty and
seize up. Much better off with a bias valve.
I’ve still got all the bits safely tucked away in a box, not that I have any intention of using it again.
Mr Whippy
posted on 29/2/08 at 02:48 PM |
sorry dude, you'll need a dual cylinder for the SVA, much safer anyway. Try a Ford cortina, escort type or a classic VW beatle (has the
advantage of a pressure switch for the lights)
[Edited on 29/2/08 by Mr Whippy]
Miks15
posted on 29/2/08 at 03:10 PM |
can you use one from the donor car? a single cylinder with a servo or is it a MUST to have dual cylinder?
iank
posted on 29/2/08 at 03:12 PM |
You can have one cylinder, but it must be a dual circuit type.
Anonymous
Mr Whippy
posted on 29/2/08 at 03:26 PM |
honesty you don't want a single system, I've had dual systems fail and it's tough stopping even with them, well scary
posted on 29/2/08 at 03:44 PM |
yep - that is how I interpret the SVA manual ablout this.
paulf
posted on 29/2/08 at 04:15 PM |
Just swap it for the master cylinder from a Sierra, the MC unbolts from the servo and just needs a new pushrod making.This is how most people do it
without a bias bar.
Paul
vinnievector
posted on 29/2/08 at 05:58 PM |
thanks guys
thanks guys think that clears things ,
