mistergrumpy
posted on 7/3/08 at 05:57 PM |
Heatshrink or Amalgamating Tape
I'v two wires running to the back for the fuel pump. I'm planning on running them in a convuluted tube to behind the seats but from there
on do I have to wrap it in tape or can I get away with heatshrink?
indykid
posted on 7/3/08 at 06:00 PM |
i'd personally run them in unshrunk heatshrink or in plastic sleeve.
you'll probably never need to strip them out of the loom again, but if you do and they're heatshrinked, it's a pita.
also, taping two wires together isn't easy option either.
tom
twybrow
posted on 7/3/08 at 06:01 PM |
I have been trying to run all my wires in convuluted tube. I think it looks neater and keeps the wires well protected. Plus if you need to access them
at a later date, you just pull the tube off again.
piddy
posted on 7/3/08 at 06:03 PM |
When I wire my cars I seal all joins using heat shrik or self almagmaging tape. The complete route in loom tape and then convuluted tube on top of any
areas that are exposed to the elements etc.
mistergrumpy
posted on 7/3/08 at 06:07 PM |
Cheers. The main loom will be wrapped in amalgamating tape where I've messed. (Though the majority of it seem to be in electrical tape from
manufacturer) Then it will go in tubing as far as. It just seemed excessive to tape the two wires in amalgamating tape and that stuff ain't
cheap.
hobbsy
posted on 7/3/08 at 06:30 PM |
There's a different between loom tape and normal electrical tape...
Sam tape and heatshrink is good and mostly waterproof but a PITA to remove as someone else said...
posted on 7/3/08 at 07:12 PM |
2 core cable
http://www.vehicle-wiring-products.eu/VWP-onlinestore/cable/multicorecable.php
RichardK
posted on 7/3/08 at 09:48 PM |
Halfrauds also sell it if you're desparate.
Rich
Gallery updated 11/01/2011
