locoboy
posted on 10/3/08 at 12:03 PM |
Tintop MOT question
Is the rear wiper on me estate tintop subject to inspection in the same way that the windscreen wipers are for MOT?
Reason i ask is that my Pug has a special fitting rear blade and its buggered, i just found out its a special fitment and its a main stealer item
only, i have MOT tomorrow and cant get to the main stealer today...........
If its not part of the test then i wont rush to replace it.
Locoboy
posted on 10/3/08 at 12:06 PM |
Not a legal requirement so not part of the MOT
Mr Whippy
posted on 10/3/08 at 12:08 PM |
remove the arm if in doubt
speedyxjs
posted on 10/3/08 at 12:12 PM |
No, definatly NOT an MOT requirement. I had a dodgy one on a fiesta that only worked in the summer, and the MOT was in November.
bonzoronnie
posted on 10/3/08 at 12:15 PM |
The rear wiper is not tested as part of the MOT
Ronnie
locoboy
posted on 10/3/08 at 02:49 PM |
Thats it then fellas,
Locoboy
ruskino80
posted on 10/3/08 at 06:23 PM |
is there not a rule that if it is fitted to the vehicle then it must work?-
hence in your case and i have done the same in the past-remove it,and it can't be tested.
posted on 10/3/08 at 07:34 PM |
No , rear wipers are not tested, same as if N/S fog light is fitted it doesn't need to work.
