Author: Subject: KpH??
A Badger
posted on 10/11/03 at 10:42 PM Reply With Quote
KpH??
Does the Speedo have to read in MPH or would a kph only one be OK (if a little bit of a pain)?
Take a look at this....
would look good in a locost...
Andrew
andyps
posted on 10/11/03 at 11:16 PM Reply With Quote
I am pretty sure you have to have mph for an MOT so probably for SVA too.
posted on 10/11/03 at 11:32 PM Reply With Quote
Main speed (ie largest digits) if twin type readings, in the UK need to be MPH. Vica Versa in Europe.
MK9R
posted on 11/11/03 at 08:04 AM Reply With Quote
You could change the spacings on the pickups for the speedo so it actually gave you mph, or get a Yellow box
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
ned
posted on 11/11/03 at 10:47 AM Reply With Quote
you could also use overlay type stickers. I've seen this done on imported bikes.
You might even get away with just marking 30,40,50,70mph on with tipex?
Ned.
beware, I've got yellow skin
MK9R
posted on 11/11/03 at 10:48 AM Reply With Quote
It would be a bit tricky using the digital read out!
Cheers Austen
RGB car number 9
www.trackace.co.uk
James
posted on 11/11/03 at 11:26 AM Reply With Quote
ned
posted on 11/11/03 at 11:46 AM Reply With Quote
oops,
didn't check the link! no one mentioned it was a digital display!
Ned.
A Badger
posted on 11/11/03 at 11:56 AM Reply With Quote
I've had a reply from the seller. It can switch to read in MPH and can connect into the vehicle wiring to power the backlight. It has even got built in warning lights and a fuel guage....
Andrew
