Author: Subject: VIN number engraving
myeates
posted on 15/4/08 at 08:00 PM Reply With Quote
hi i tried to stamp my chassis last weekend but it would seem my stamps arent very good, or was just me, tried on a bit of 1 inch box section first and they just bent it with barely a mark there, just a mess.
the question is is there any good online places that can stamp or engrave the vin into a mild steel plate that i can weld onto the chassis, can i get this done by someone like timpsons? have stamped alloy plate to rivet eslewhere as i can manage that but this wont be enough
or is there anyone on here that can stamp it for me properly on a plate to weld on?
thanks in advance
posted on 15/4/08 at 08:05 PM Reply With Quote
Take a bit of stainless plate into an engraver/key cutter/Fishing Trophy place and they'll do it for you for a relatively small fee.
Ours is just rivetted onto the battery tray. This was fine for our SVA, but that doesn't mean it will be ok for yours. Go figure...
caber
posted on 15/4/08 at 08:10 PM Reply With Quote
get a strip of thinish steel say 1.6mm put it on top of a thick heavy bit of steel say 6mm then try using the letter punches, you should get a nice clear impression. Once its done weld it onto the chassis probably over yuor bent bit of box section. job done and tidied up mess!
Caber
RazMan
posted on 15/4/08 at 09:54 PM Reply With Quote
I went with the stainless plate option and got it engraved and then rivetted it somewhere prominent so it looked pretty - the bodged stamped version is somewhere invisible I had it in my pocket for the SVA test
Raz
