stuart_g
| posted on 10/5/08 at 02:04 PM |
R1 dash SVA Q.
I can not get the dash within the exempt zone and as the R1 dash will fail if it is outside of the exempt area I have made this fiberglass recess to
house it. It will also tilt the dash toward the driver making it easier to read.
Am I right in thinking that anything outside the exempt area will be ok as long as it is below the level of the dash? The recess will be glued around
the lip with PU adhesive and is radius'd. The R1 dash is lower than the lip so does not pretrude.
What do you think?
Hammerhead
| posted on 10/5/08 at 02:12 PM |
Looks really cool. well done.
If you are still worried you could double sided tape a bit of perspex over it to get it through SVA.
Humbug
| posted on 10/5/08 at 02:53 PM |
I agree with Hammerhead... I think whatever is used to check radiuses would/might be able to contact the edge of the gauge, so better to put a
perpex/lexan cover on at least for the test
stuart_g
| posted on 10/5/08 at 07:45 PM |
What a good idea, thanks chaps.
adithorp
| posted on 10/5/08 at 08:07 PM |
I had the same problem and made a shield to cover the area that isn't exempt.
Before
http://i189.photobucket.com/albums/z282/adrianthorp/fury086.jpg
After
http://i189.photobucket.com/albums/z282/adrianthorp/Pre-SVA003.jpg
adrian
