tony9876
posted on 3/12/03 at 10:41 AM |
Steering Wheel
Does anyone know the regulations regarding steering wheels?
Thanks.
P.SWhere can I get a copy of the SVA manual.
Tony
posted on 3/12/03 at 11:24 AM |
OTTOMH, i think it must be padded, and no holes to trap fingers. Then the size affects the radius exempt area behind it...
http://www.jpmast.nl/svaChapters.htm
try this for help.
Simon
posted on 3/12/03 at 11:51 AM |
Tony,
Best idea is to use the donor wheel, for two reasons.
Firstly, it's a previously type approved item, so shouldn't have any SVA hassles.
Secondly the exempt area around the wheel is IIRC 127mm. So after you've had your test, and you put on a 3" dia wheel, you'll be
able to see the gauges you squeezed into the gap
Simon
tony9876
posted on 3/12/03 at 05:15 PM |
Simon I am building everything new so there isnt a donor vehicle mate. The wheel i have doesnt have holes in it and is leather padded so it should be
ok. I have racex digital guages which i am going to flush fit so i should be ok there as well.
stephen_gusterson
posted on 3/12/03 at 07:29 PM |
the wheel is a bit of a minefield. SVA says it needs to be approved as part of an approved steering assby.
its gotta be Emarked.
most people fit a std steering wheel that comes with the steering assby, and then change it after sva
atb
steve
