myeates
posted on 22/6/08 at 02:14 PM |
broken fuel sender, and sva next week
hi guys i have just found out my fuel sender has stopped working internally so the fuel gauge doesn't work, my filler is on the top so you can
see inside what is in the tank but the question is, is this going to be a problem for the sva i know the tank needs to be full which can be checked
without problem but im not going to have time to change this before the sva
look forward to your replies
regards
mark
Paul TigerB6
posted on 22/6/08 at 02:17 PM |
I'm sure you'll be fine as there is no requirement for a fuel guage. As you rightly point out, you just need to have a full fuel tank so
if you can see the level through the filler i'm sure you will be fine.
posted on 22/6/08 at 03:09 PM |
^^^ yep; wot he says.
fuel gauge not needed for test.
myeates
posted on 22/6/08 at 10:12 PM |
great thanks guys will fix after test
