COREdevelopments
posted on 6/7/08 at 09:07 AM |
koso speedo setup
hi all, second posting as no one has replied to other one. i have been attepting to setup my koso speedo. has anyone got any idea how to set it up. my
sensor and 4 magnets are on the prop, im running 195/50/15s and i think it may be running a 4.3:1 diff ratio.
any help is greatly appreciated as sva is on tuesday and am bricking myself.
thanks
rob
vorn
posted on 6/7/08 at 09:34 AM |
I could be wrong but when I read my Koso manual ( along time ago !). you have to tell it how far yo travel between each magnet pulse .
So I would
1/ mark the ground and tyer with a piece of chalk
2/roll the car round one rev of the wheel and mak the ground again
3/ measure between the two marks on the ground
4/ divide the measurement by the number of magnets ( divide by four in your case ) and this will give you the number to input into the koso unit .
You dont have to worrie about diff ratios and tyers sizes as the the drive shaft turns a fixed amount of times per rev of the wheel .
Hope this helps
Please let me know if it works for you .
Vorn
[Edited on 6/7/08 by vorn]
cloudy
posted on 6/7/08 at 10:19 AM |
Just to add to this - you don't divide by the number of magnets - the koso has a seperate setting for how many magnets you are using I
believe....
James
www.warnercars.com
COREdevelopments
posted on 6/7/08 at 04:22 PM |
thanks guys your life savers was getting worried then. i will give it a try.
thanks again
rob
richardh
posted on 6/7/08 at 04:48 PM |
not the prop
koso has to go on something with circumference of 300mm or over......
if not forget accuracy.
i had this confirmed direct with them.....
what engine you running?
Valtra
posted on 6/7/08 at 09:57 PM |
quote: Originally posted by richardh
not the prop
Rear brake drum ? Hub ?
COREdevelopments
posted on 7/7/08 at 01:03 AM |
im using a toyota 4age. too late now as i have already fitted it and sva on tuesday!!
il try it as it is and see how it performs.
rob
