Author: Subject: Has anybody used these Brake pipe / wiring clips for SVA
madrallysport
posted on 24/7/08 at 09:14 AM Reply With Quote
Going to pipe my car this afternoon. I have p-clips but i also have these clips (Clips Linky) . I used these for brake lines on the inside of rally cars, rivot them in then cable tie pipes / wires to them, but will Mr SVA man allow them. Any help would be great.
[Edited on 24/7/08 by madrallysport]
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
nib1980
posted on 24/7/08 at 09:21 AM Reply With Quote
I used Pclip on my brake lines, and the others for my harness with no concerns.
richardh
i used them with no probs - every 6 inches i did mine (not sure the exact measurements for sva but he was fine)
adithorp
posted on 24/7/08 at 09:51 AM Reply With Quote
Can't see a problem as long as you either rivit or screw them on. In the SVA book, Max' spacing is not defined for brake pipes, it just says adequatly secured (or something similar) but it says 30cm for loom wiring.
adrian
