Author: Subject: SVA and Headlights
myke pocock
posted on 30/7/08 at 09:59 PM Reply With Quote
SVA and Headlights
A previous post has got me a bit worried and seeing as I got no replies there I am asking the question here. I bought a pair of headlights through the Locost Owners Club some time ago as a special deal (!) They are marked on the glass as :- A E11 7603 USA LEFT and Wagner (presumably the maker?) Are they for left hand drive?
adithorp
posted on 30/7/08 at 10:29 PM Reply With Quote
I'd normally expect the "left" to be the diection they dip to. Connect them to a battery and shine on a wall and see which way they go. You should have a kick up on the left hand side of the beam pattern when the lamp is level.
adrian
miikae
posted on 30/7/08 at 10:52 PM Reply With Quote
Just checked my old 7" Wagners and yes yours are uk spec , the same numbers as on mine , also above the left it should say drive , which i take it means that it dips to the left , hope this helps .
Mike
If it can be done it i will be done .
