donut
posted on 31/12/03 at 10:29 AM |
Emissions / Cataclean
Ok yes i'm VERY sad but i have just been watching the QVC channel and noticed (while surfing through) some stuff they were selling called
Cataclean. This stuff is a liquid you put into your fuel tank which cleans your cat converter. It also cleans the engine and reduces the Hydrocarbon
and CO readings.They tested the stuff on the presenters car and without fiddling with the engine it reduced the readings significantly!
Web address is http://www.systemproducts.com/Pages/product.html
May help the emissions test for SVA even if you don't have a cat fitted.
theconrodkid
posted on 31/12/03 at 01:09 PM |
99%of these "wonder treatments" dont work,just get it nice n hot to clean the cat.
who cares who wins
pass the pork pies
Mk-Ninja
posted on 31/12/03 at 03:01 PM |
It will work wonders on your wallet
Gordon
[Edited on 31:12:03 by Mk-Ninja]
I'm sure I've got one, just don't know where I've put it
donut
posted on 31/12/03 at 03:03 PM |
it was just a thought!!!!!
Ben_Copeland
posted on 31/12/03 at 07:41 PM |
Noooo dont do it... they are all crap. If they do work, you either end up 2 weeks down the line back to where you were, or it ends up worse!!!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
blueshift
posted on 1/1/04 at 12:28 PM |
Bizzarely I saw the same advert while channel-hopping. Looked like a scam to me too.
posted on 1/1/04 at 09:42 PM |
i used a similar thing to get thru the mot once, its only a short term fix but it got it thru ok. not sure if the tester couldnt be arsed failing it
again or if it actually made a difference, but was ok by me!
