givemethebighammer
posted on 5/1/04 at 09:34 PM |
Fuel hose clips
This queston has been asked and not answered on the westy forum:
Whats the difference? After reading through a few different SVA guidelines it seems securing clips and not jubilee clips must be fitted to the fuel
hoses.
Is this correct? If so whats the difference and where do i get them from?
Interested in the answer because I have used jubilee clips throughout.
zetec
posted on 5/1/04 at 10:16 PM |
If you mean the clips to join two pipes together...Fuel pipe clips have a continue band on the inside which gives a more even grip and will not damage
the rubber pipe. Suspect there is really very little benifit in their use but if it is for SVA then so be it. Most motor factors have them on the
shelf and probably cost less than jubilee clips. They tend to use a small nut and captive nut to tighten the clip.
Northy
posted on 5/1/04 at 10:43 PM |
I got mine from a local motor factors. IMHO they are better than jubilee clips.
If you can't find them, I'm sure Halfords will have some, but at what price
Graham
stephen_gusterson
posted on 5/1/04 at 10:58 PM |
europa spares sell em, halfords only seem to sell em in a pack with 1mtr hose for about 8 - 10 quid
atb
steve
givemethebighammer
posted on 6/1/04 at 12:48 PM |
Got some, £1.49 for two at local motor factor.
Can't see any real benefit over jubilee clips other than they may be less damaging to the petrol pipe. But what Mr SVA wants MR SVA
gets............
posted on 6/1/04 at 01:21 PM |
The trouble that can sometimes happen with jubilee clips is that when tightened up really tight they can distort the tube into a 'pinch'
next to the screw adjuster, which can allow petrol past.
Theoretically the proper clips don't do that - the downside is that you have to get the right size as they don't have much of a range of
capacity.
But, in the end, it's just as you say - the tester may well expect to see the right ones, so you might as well get them!
DEAN C.
posted on 7/1/04 at 08:53 PM |
Hi, Seeing as the Goodridge type anodised fasteners use a jubilee type clip inside I presume that this is a fail?
Or does anyone know different.
If they are a fail I'll probably fit proper double crimp type clips as used on fairly high pressure industrial & hgv fluid/air pipes .
These are rated for anything up to 150-200 psi and tighten evenly around the pipe.
Once I've finished a project why do I start another?
titch
posted on 7/1/04 at 09:16 PM |
I KNOW ITS NOT THE PLACE
WHEN DEAN C READS THIS CAN HE CHECK IN "ANYTHING ELSE"-UNDER OLD MATES,MAY BE ABLE TO GET IN TOUCH THEN!
posted on 7/1/04 at 10:02 PM |
that thread still makes me chuckle...
TPG
posted on 15/1/04 at 10:19 PM |
Jublly clips thru out the petrol system on mine.No problem at recent test pass.Not even a "I would of prefered to see..."
stephen_gusterson
posted on 15/1/04 at 10:25 PM |
jubbly clips look so painful - wouldnt have mine pierced for anything!
seriously, I have read of fails for wrong kind of clips
atb
steve
