New Topic New Reply
Author: Subject: Supporting your chassis
EasyJimbo
posted on 26/9/08 at 11:57 AM Reply With Quote
Hi
Can anyone point me in the direction to what you are using to support your chassis while building. I know I could use axle stands, but I wonder if anyone lese uses bench stands under the floor of the chassis, which then sits on these one at the front and one at the rear. Can anyone recomend where to get these from and what they are called?
thanks
J
marmot0
posted on 26/9/08 at 12:05 PM Reply With Quote
http://www.screwfix.com/prods/23565/Hand-Tools/Workbenches-Trestles/Sawhorse/Fatmax-Telescopic-Metal-Sawhorse-Twin-Pack
Used these no problems, just think about how you get it off them when you finish
dunk3
posted on 26/9/08 at 12:06 PM Reply With Quote
chassis stands
i bought mine from b&q they are the stanley fat max saw horse with adjustable legs they will surport up to 2500lb per pair . £30 each
Paul TigerB6
posted on 26/9/08 at 12:11 PM Reply With Quote
I've got some similar to the Screwfix ones. Some foam pipe lagging on the top is worthwhile to protect the chassis finish
Stuart_B
i got a pair of saw horse from b and q for £25the pair and done the job great.
stuart
EasyJimbo
posted on 26/9/08 at 12:15 PM Reply With Quote
thanks Guys, I see the cheaper ones only have 250KG capacity, is this enough for a rolling chassis..?
J
jollygreengiant
posted on 26/9/08 at 12:18 PM Reply With Quote
I made wooden horse for about £15.
They got passed on to a second builder.
iank
posted on 26/9/08 at 12:26 PM Reply With Quote
I'd say make your own from 2x4 rather use the cheap plastic ones.
Horror Story of Plastic stands breaking
Anonymous
drlloyd
posted on 26/9/08 at 01:08 PM Reply With Quote
Locost method - Old Car Tyres!
James
posted on 26/9/08 at 04:12 PM Reply With Quote
My plastic stands broke too when I dropped the chassis whilst rotating it on my own!
James
mcerd1
posted on 26/9/08 at 04:34 PM Reply With Quote
I made my own out 50mm steel box & angle - they're really solid
I wrapped some strip I found rubber round the tops to save scrapeing the chassis
posted on 26/9/08 at 05:26 PM Reply With Quote
Milk crates. They're incredibly strong, cost nothing and can be handed back to your milkman when you've finished with em.
Phil
Ian D
posted on 26/9/08 at 07:44 PM Reply With Quote
I also used the saw horses from screwfix. Went to 4 when I fitted the engine in. Best thing is they create a good working height for you.
Michael
posted on 26/9/08 at 08:23 PM Reply With Quote
Has been on Home Made Wooden Saw Horses (normaly made from roof or floor joists.
Currently on Axle stands, set at the highest, which leaves car about 17" from the ground.
MautoK
posted on 30/9/08 at 07:50 PM Reply With Quote
I made a table/framework about 8 ft x 3 ft x 3 ft out of speedframe with wood planks to protect the paintwork.
Saved no end of backache! I already had the speed frame, otherwise would have made a similar frame from 4 x 2.
MikeR
posted on 3/10/08 at 11:46 AM Reply With Quote
I went to B&Q and bought two of the 10 pound work mate equivilents. Put the 1" lump of MDF reinforced with steel ontop of it and build the chassis on that.
They'll take 250kg and have a margin of safety build in. For what i did, i was ok. If you're worried get three, one at teh front, one in the middle and one at the rear.
Biggest problem you'll have is getting the car off them.
iank
posted on 3/10/08 at 12:01 PM Reply With Quote
Biggest problem is they can break if they see any significant twist well below their SWL.
Anonymous
Simon
posted on 6/10/08 at 12:30 AM Reply With Quote
I used the floor till I had running gear fitted, then mounted it on its wheels.
Can't get much more Locost than that
Simon
posted on 7/10/08 at 07:53 PM Reply With Quote
Give it a round of applause, not much more support needed IMO.
New Topic New Reply
