Dick Axtell
| posted on 16/10/08 at 02:58 PM |
Fog & Reverse
Any height restrictions on these two lights, on the rear panel?
I was planning to put them approx 50mm below rear top rail, in order to avoid fouling back of fuel tank.
stuart_g
| posted on 16/10/08 at 03:01 PM |
This should answer your question
Dick Axtell
| posted on 16/10/08 at 03:18 PM |
Spot on, Stuart!! Thanks for very clear info.
So, I was OK to put fog and reverse up high - except for one parameter.
Fog has to be 100mm MIN spaced from rear light (as you showed).
Guess I'll have to fix the rear light assys first.
