LBMEFM
| posted on 21/10/08 at 07:45 PM |
Nut Covers
Maybe a daft question, but do I need to put covers on the bolt heads as well as the nuts for SVA?
blakep82
| posted on 21/10/08 at 07:51 PM |
i think so. those sharp hexagonal corners might cut someones leg off
________________________
nitram38
| posted on 21/10/08 at 08:29 PM |
Only the exposed ones on the outside of the car and in the cockpit, not every bolt on the car.
There are also exclusion zones where you cannot reach the bolts, like behind the wishbones, but best to do them all externally. You can always take
them off after the sva.
StevieB
| posted on 21/10/08 at 09:05 PM |
It's all just in case a small child gets their head caught in the suspension - an exposed bolt head could result in a nasty cut...
Do what Nitram said though - failing SVA for exposed edges is a bit daft seeing as it's so simple to avoid
mad-butcher
| posted on 22/10/08 at 08:59 AM |
sorry about quality of photo.
make sure you get the right type the ones of the one on the left will fail sva on sharp edges
Mine came from tifosi
[Edited on 22/10/08 by mad-butcher]
