Richard.D
posted on 21/10/08 at 08:48 PM |
clutch and accelerator cable
Hi guys,
Just completing an installation of the fireblade engine in my MK. What have you all used for clutch and acc. cables? Have you used std bike ones? Are
they long enough? Where did you buy them from?
Thanks.
Mark G
posted on 21/10/08 at 09:32 PM |
I've got a couple of universal cables from ebay, I think I paid around £11 or £12 each for them. I thinik they may be by Venhill.
I haven't fitted them yet so can't say if they'll be perfect but so far they seem to be ok.
Mark G
posted on 21/10/08 at 09:35 PM |
Throttle cable
Clutch cable
YQUSTA
posted on 21/10/08 at 10:26 PM |
My clutch cable is huge 6-8mm and was fitted when i got the car so dont know where its from.
My throttle cable was replaced the other month and I got a kit from Hein Gericke and was only a few pounds.
It came with all the bits you will need and is plenty long enough.
YQUSTA
Richard.D
posted on 22/10/08 at 07:23 AM |
Thanks Guys
Thanks for the links.![](/images//smilies/wink.gif)
tomblyth
posted on 22/10/08 at 08:33 AM |
if you need cables try hein gerick the bike shop (it universal clutch cable is 2.5mm (same as some hanbrake cables) the outside sleeve is easy it
trim to size ( grind it to keep clean end). there about £3 each
Dangle_kt
posted on 22/10/08 at 04:03 PM |
I got my cables from MK, they sell the proper clutch cables. Becuase its done with your foot the cable gets a hammering, and you will read of many a
snapped clutch cable.
Much better to buy the proper thing.
Not such a big deal with the accelerator cable, but as I was on to them i got them both from them.
