Brake pipe route
JeffJeffers - 18/7/10 at 10:16 PM
Has anyone got any pictures of where to run the brake pipes on an MK Indy R.
I'm a little nervous about drilling holes in the wrong place.
I have searched but I can only find pictures of MK Indy's.
Steve Hignett - 18/7/10 at 10:21 PM
Don't overthink your build or you'll be building forever and never driving.
The route the Indy brakes take will be the same as the R (give or take!)
Steve Hignett - 18/7/10 at 10:23 PM
You could have a gander here:
http://www.p4nts.co.uk/specr
main82000 - 18/7/10 at 11:56 PM
hi there
im in the same boat as you keep putting it off but its time to dive in if i find anything ill let you know but what i will say is the main brake line to the rear seems to be far to long do you have that as well
craig
40inches - 19/7/10 at 09:35 AM
craig
The brake line has to run from the master cylinder to the rear caliper/drum, how could it be shorter? Or if you mean the pipe as supplied with the kit, run it from the master cylinder back and cut off any excess and re-flare.
As already said, don't over think it, run the pipe through the tunnel,top,bottom or sides, your choice, clip every 300mm and do it before you panel the tunnel
dhutch - 19/7/10 at 01:16 PM
Sounds like sound advice to me!
MikeR - 19/7/10 at 01:40 PM
i'm on year 10 of my build ........ guess what i keep doing!!!!
40inches - 19/7/10 at 01:46 PM
I can't think!
main82000 - 20/7/10 at 07:26 PM
hi there
yes sorry i meant the pipe that came with the kit is to long as you say i will need to cut and re flare craig
JeffJeffers - 20/7/10 at 09:21 PM
If the pipe is to long you need to cut it to size with a pipe cutter. Then use a tool to flare the end again.
http://cgi.ebay.co.uk/DRAPER-37870-BRAKE-PIPE-FLARING-TOOL-KIT-7-PIECE-/150464712738?cmd=ViewItem&pt=UK_Hand_Tools_Equipment&hash=item23086550 22
afj - 21/7/10 at 09:37 AM
There are loads of indys around peterborough/spalding/holbeach areas some one will be willing to give you some pointers i could take a drive over at the weekend to give you a hand for an hour or two or have a search on google for mk indy hellfire there are pleny of pics there not a indy r but its all the same really
alan
40inches - 21/7/10 at 09:59 AM
Brake line on left, fuel on right
Brake line
Brake line
JeffJeffers - 22/7/10 at 09:56 PM
alan
Thanks very much for your offer but I'll have a go myself 1st and when it all goes wrong I might take you up on it!
