is there any rules on which side of the driver seat the lever has to be on? i don't think so, but want to be double sure. as long as it can be
reached/operated i think
has anyone on here managed to do some kind of electric hand brake yet? i'd like one, i haven't got anywhere on my pickup to mount a normal
lever, the tunnels not strong enough. the seat mounts is the only place, but its tight for the seat already anyway.
a simple push button job would be nice, but i don't really get how they work
[Edited on 26/8/08 by blakep82]
No rules on where handbrake need to be, but should be easily operable from the driving position so i was told at SVA.
So how some people get away with them under the passenger side of the dash is beyond me...
I have fitted an electric handbrake to my mk it is made from a sunroof motor that turns through a bevel gear set up that operates a screw thread to pull the handbrake cable all operated by a dash mounted toggle switch and it fits in the mk transmition tunnel.
have you sva'd yours yet/with it fitted?
I'm not entirely convinced electric ones are any more reliable than say a hydraulic line lock, but i see electric ones on production cars, so
would be quite good.
I sva'd the car a long time ago but it has been through an mot the way its made once applied it cannot come off even if the power is cut this gets round the rule of it failing over time if left on (that is the problem with hydrolic ones) it is also only opporational with the imobaliser chip and ignition key in (to stop idiots turning the handbrake off for fun)
hydraulic line lock
ah, sounds perfect! is it one you made yourself, or can it be bought anywhere?
Originally posted by omega 24 v6
hydraulic line lock
Sva fail that one. It has to be a mechanical type handbrake i.e. separate from the hydraulic lines. Electric should be OK but don't quote me
Originally posted by blakep82
is there any rules on which side of the driver seat the lever has to be on? i don't think so, but want to be double sure. as long as it can be reached/operated i think
its one i made myself its actualy a worm wheel turning a bevel gear screwing a screw thread pulling the brake cable
it sounds complicated but it isnt realy it gives an amazing pulling power and cannot unscrew itself the reduction gearing is too great
not bad
think its one for each wheel, but a lot cheaper than i'd expected
hi blake
sometimes the cable is pulled by a spring and the electric motor works against the the spring to release the brake
ie ..in acomplete fail of every thing electrical the park brake still holds
hth
les g
blake look at the hilux hand brake
had a search but i couldn't find any info on the hilux... i did see somewhere something about a rheostat, its like a variable resistor to control it? sounds good. though i do like the idea of just a toggle swith, or push buttons, but something a bitmore variable would be cool
Originally posted by les g
hi blake
hth
les g
