sorry for the massive pic, but i have a leak on my axle, were can i get new oil seals or whatever is needed?
cheers
oil leak
Hi
Pretty sure the seal is part of the bearing, and they ain't straight forward to change.
Shaun
im sure i can get them changed if i can find the parts?
Try Nick at Newford. Here is his details. If he hasn't got any I am sure he will be able to help you locate something.
Newford Parts Centre
Abbey Mill,
Garden St,
Abbey Village,
Chorley,
Lancashire
PR6 8DN
Tel: 01254 830343
Hi there
I have same problem to fix on my escort axle. The seal and bearing is not exactly a DIY job being heat-fitted onto the shaft end.
Can be done but sounds a really medieval task to accomplish at home (hot oil, bbqs, hammers..) - search on past threads as there is a fair amount of
excellent advice on this.
Not an easy task!
Hi, it's been covered before, it's a simple enough job really, we used an angle grinder with cutting disc to get the old one off. and a home
made press to put the new one on.
Like I say it's been covered before, here's the original thread, hope it helps.
LINKY
I had the same problem with my axle.
I changed the bearings and Voila! it still leaked
