SVA friendly steering wheel ?
dogwood - 6/11/08 at 07:20 AM
Hi
I cant fit a standard Sierra wheel because it obscures the speedo.
So I did this.
I hope it's SVA friendly. I have got a collapsible wheel boss
What do you think?
Humbug - 6/11/08 at 07:24 AM
Looks like it should do the trick as long as the edges of the red button are radius-friendly.
When you fold the tabs back you could fix them with double-sided foam tape so it looks more "permanent"
dogwood - 6/11/08 at 07:28 AM
Maby I'll have to stick some foam on that as well
speedyxjs - 6/11/08 at 07:37 AM
Nice job
[Edited on 6-11-08 by speedyxjs]
iank - 6/11/08 at 07:59 AM
That was exactly my first thought, looks a bit sharp edged.
It's really quite good and a useful idea considering they don't make pads for a lot of the wheels these days.
Dangle_kt - 6/11/08 at 09:05 AM
Great idea - I shall be copying that, as my steering wheel is no good either.
What did you use to cut it out with?
02GF74 - 6/11/08 at 09:24 AM
good job!!
steering wheel!?!?!? more llike a shirt button.
BenB - 6/11/08 at 12:00 PM
Nice work!
dogwood - 6/11/08 at 05:50 PM
4" angle grinder with ultra thin cutting disk.
and a lot of filing
pocket rocket - 6/11/08 at 06:16 PM
doesn't the center of the steering wheel have to be a sure hardness of 50 to please the sva man?
Hellfire - 6/11/08 at 06:20 PM
Just fit the Sierra steering wheel for SVA. I'm sure it doesn't obscure the speedo to the point where you can't even see it. Or does it?
Phil
dogwood - 6/11/08 at 07:37 PM
WHAT !!!!!
Oh well back to the drawing board
and yes H/F it does obscure the speedo.
right through the middle of it.
BTW what is sure hardness of 50 anyway ?
I assume it is harder than the foam I used
What could I use instead
Hellfire - 6/11/08 at 07:50 PM
Don't think it's stated anywhere in the SVA manual that the speedo must not be obscured.
Phil
dogwood - 6/11/08 at 08:39 PM
I just checked the SVA manual
It says:
"Check that the spedometer is capable of being read at all times of the day or night, eg by illumination
Note: Temporary obstruction by the steering wheel is acceptable"
So I definatly think not being able to see all the speedo is a fail
