Hi,
My Luego Velocity has been set up by eye or feel and after 1200+ miles I think that it is time to get it sorted out. Does anybody know of a company
that can do this sort of thing with in a short drive of Sunny North London by chance?
Regards
If you find one let me know!
I was planning to give these guys a go next year
Racecar Doctor Link
Stu
Spirit level, pound shop laser level and 4 sets of Tesco bathroom scales (and a couple of hours) worked for me!
I setup my camber with a metal bar and an inclinometer off Ebay. Set the virtual zero across the engine bay rails and then measure the readings off
the inclinometer when its attached (most have magnetic bases) to the brake disc.
For toe in / out I used an oversize caliper that. Simple to make with a welder, difficult to describe
Measure the distance between the back of the
front tyres, ditto re the front of the front tyres, bit of trig and voila.....
Set mine up with home made camber/castor gauge and toe in/out gauges, and a spirit level. Worked fine for me.
