Im not fitting a windscreen,will i need the standard sierra stalk that controls all the wiper action?
no, although you could use the washer push button for the horn.
Mot unless your going to have wipers that flail around in the air but i dont think mr SVA will apreciate that
Quote "Mot unless your going to have wipers that flail around in the air but i dont think mr SVA will apreciate that"
Im Not fitting a widscreen so the wipers will be pretty useless?!?!?
I sawed off the wiper stalk and gooed up the hole with PU
I just used a dash switch to turn the lights on and dumped that stalk.
I left it on cos I put the screen on afterwards. Having switches doing nothing isn't a problem. I had an unused switch on my dashboard. Perhaps
the tester thought it was an oversight. I new it was for the demister once I completed SVA and put the screen on.
