Hi all,
I have just recieved my new wilwood "Midilite" brakes from Rally Design, i started fitting them this evening, all was going well until i
offered up the caliper to the vented disk and it wont go over the disk even without the pads in its still to tight am i doing something wrong, or have
i been sent the wrong disks if it helps the disks are 22.5mm in width are they to wide??
Also i had a spring in one of the caliper boxes but not one for the other side, whats the spring for??
Any help much appriciated
Greg
are the discs meant to be vented? i have the solid ones, i think there about 15mm thick max. maybe youve been sent the wrong callipers?? mine went togethert beautifully...
the spring is for rear calipers its part of the handbrake tensioner
Thanks for your help!!
i rang rally design this afternoon and after a lot of going through product codes and what could be wrong A1 you were right it turns out the wrong
caliper was in the box so the product number was correct but the wrong caliper was inside. Really annoying as i paid extra to get these painted red!!!
and there wrong!!
may not see them this side of xmas now either.
