sierra rear caliper fitting
blakep82 - 13/12/08 at 12:15 PM
can banjo fittings be used? how flat/smooth does the body of the caliper need to be? mine are quite rough i think. not sure if trying to file them flat is a good idea or not (with bolts in the inlet to stop any gubbins getting in
mad-butcher - 13/12/08 at 02:10 PM
I had banjo hoses made for the back of the indy, Didn't work for me,bottom washer kept leaking even with recon calipers, you may be lucky
tony
blakep82 - 13/12/08 at 02:12 PM
normal male fitting it is then perhaps
