I am trying to find somewhere online that sells 260-265mm solid cortina brake discs. I have been on a number of sites and they only list the standard 247mm discs. Some brake kits specify larger discs but I cant seem to find the discs on their own. I would also like them drilled and grooved if possible.
What Cortina had the larger discs?
None of them as far as I know. I thought they were all 244 or 248mm.
The only ones that I know that are bigger than this that MAY fit are the RD ones for the Escort using the Princess 4 pots. I think that they are 257mm
or thereabouts.
Were'nt the 260 disc's a special , for fittin with princess calipers ?
Something that Rally Design might have ?
I'm pretty sure I need 265mm discs.
Rally Design show a wilwood brake kit for Cortina uprights with 265mm discs so I'll give them a ring and see if they are available seperately.
Stu.
Hi stuart, MNR supplied ours and im pretty sure they originally came from Rally Design and they are 265mm solid but are grooved and drilled, got them
at the same time as some wilwood powerlite calipers which need the wilwood bracket and spacers
[Edited on 30/12/08 by bassett]
