Hi, does anyone know the socket size for a sierra rear hub nut?(with discs if it makes a difference)
46mm and they have opposite threads.They tighten towards the front of the car.
You will need a long lever to undo them....
Off the top of my head 41mm springs to mind. I'll just go and check.
41mm
There's one on Ebay - linky
Yep, mine are 41mm. It was originally a drum set up though, so not sure if the disk ones are different?
Mine are discs and they're 41 too.
Thanks, will go with the 41mm one as i had measured it but ours is as old as the sierra it came off and isnt in the best condition so wanted to be
sure.
cheers
[Edited on 2/1/09 by bassett]
Mine's a 41mm x 3/4" Draper socket which I had to buy a 1m x 3/4" braker bar for but this didn't provide enough leverage so I went to BSS plumbing supplies and bought a 3m length of steel pipe to go over the breaker bar. Once I'd attached a towing rope between my Sierra donor and own car to stop the Sierra moving with the torque of the breaker, all the nuts came loose without a fuss.
Yes 41mm
Usually a bitch to shift.
I welded a bit of box to a scrap disc and then levered it against a tube inserted in the box section.
It still bent a decent bar in my socket set.
But then I did have a 3metre bit of scaffold on it!
Made it dead easy, and the old disc was scrap anyway!
Are your Nuts Too Tight?
[Edited on 4/1/2009 by wilkingj]
