Now I've finally got over the headache of wide track wishbones, I am looking to source the bushes.
I intend to use the 25mm x 2mm CDS tube for the bush tubes (I have plenty spare to use) and I already have the standard 'book' mounting
brackets (38mm between faces and M10 mounting hole).
So I will be needing bushes with 21mm OD and crush tubes of 38mm length (max) with M10 centres.
Anyone got any advice on where best to get these?
My other option is to obtain the Triumph Herald Isolastic bushes as quoted in Ron's book but I would sooner get Poly.
JB
I still like the idea of rubber bushes for the road. To much vibration and noise from poly ones.
linky
linky 2
near the bottom
119451 WISHBONE BUSH - RUBBER £0.85
Thanks Chap
Do they come with inner tubes or do I need to order them seperatley?
Lots of questions I know, but don't worry, I won't ask you to order them and fit them too
on a rubber bush the innertubes should be bonded in.
If using Spitfire bushes note they are 3/8 bore not 10mm, so 3/8 bolts might rattle in your 10 mm holes
OK, thanks guys.
BTW, JeffHS, will it be such a problem if the bushes are 3/8" and the brackets are M10? Surely 0.5mm won't be a problem once the bolts are
tight?
JB
As a matter of interest in the rubber v poly bushes debate I had my car set-up by the local race shop over Christmas. They suggested fitting poly
bushes to the rear (four link + panhard) as the rubber ones drag as they move up and down affecting the ability of the rear axle to follow the road
surface. Probably doesn't have a huge effect in normal driving conditions but worth bearing in mind if you are contemplating competition.
Cheers, Pew
Or make a very small o ring to compensate the gap.
