Hi all
I have a couple of questions that I was hoping people could give me their opinion on:
1. I have a choice of a 7" 3.62 diff from a 1.8 sierra diesel and a 7" diff 3.62 from a Sierra XR4x4 (which I believe has an LSD, but not
sure)
Is it worth getting the LSD for a zetec engined locost? (soon to be turboed)
2. How much should an LSD axle cost me
3. Can the bolt on shafts from the LSD units be used with the brake drums of a push in shaft version?
As I don't think the brake discs would fit in the wheels. (And I actually quite like the current drum set up which has rear drums.)
Lars
Hi Lars,
personaly i would go for the lsd from the 4x4.great on a turbo zetec
The 7" and 7.5" shafts are not interchangeable to my knowledge,
the bearings in the hubs are
a different size to start with.
Some research suggests that prices are around £150, so I have answered my own question.
Sorry Andy, I did not mean whether 7" and 7.5", shafts are interchangable, as both are 7". But I was hoping to bolt the brake drums and
hubs to shafts from a disk braked diff.
(if that makes sense)
the bolt on shafts are found on rear disc equiped cars and use larger rear hub brgs, also the LSD diff, driveshaft flanges are different to NON lsd (longer) so you cant remove them and swap to push in shafts, as you can with a non LSD diff
So I would have to get special shafts made that go from a bolt on diff to drum hubs.
Which may be OK as I need shortened shafts anyway.
I also see that the LSD vs non LSD has been discussed a previously, so I withdraw the question. (However thank you Andy for your view)
Lars
Lars,
All you need to do is change the push in CV joints for Lobro bolt on ones from bolt on shafts.
That is what I have on mine, a 3.62 LSD diff with drums, using push in shafts with lobro joints.
Rescued attachment Shaft 2.1
2
Rescued attachment Shafts After.1
Just picked up a Cosworth 4x4 rear diff yesterday - £100 from someone breaking a cossie on the bay.
Got the driveshafts, uprights and hubs off him as well, £90 for those so £190 all in.
Everything is going to be totally stripped and given the electrolysis treatment, repainted then reassebled with all new bearings and seals
Sean
[Edited on 11/1/09 by londonsean69]
so if one used a non lsd for mocking up purposes,one couldnt swap in an lsd equipped diff at a lter date and the dimension accross the flanges is different?
Thats how i read bigrich at first but i dont think thats what he means.
I think (correct me if im wrong Rich) that the bolt on diffs are all the same outside whether LSD or open. Insides may be different, ive never opened one.
I would hope to find a full xr4x4 rear assembly for £150, thats what i sold them for in the past. Cossie ones are 7.5" (again, correct me if im wrong) so cost more.
[Edited on 11/1/09 by JoelP]
