What's the best material to make these from, I've seen them in 3/4' & 1' tube, and 1' RHS. Does it matter??
I know my build is different but I do have loads of links at the back and I used 1" dia x 16g for mine. Some ends have inserts for Heim/rose joints
and some ends have short bushes for rubber or poly bushes (i.e. book style)
I think if the welds are good all those options would be fine. So IMO, no it doesn't matter that much.
Mine are 3/4" tube, as I'm sure you saw on Sunday. Can't see that it would make much (if any) difference.
Chris
You could use 1" dia tube or 1" RHS, it's up to you! (they're the same thing!) Round Hollow Section. Tell me how much you need and I'll throw it in
with the order!
Jasper,
Nissan Bluebirds have adjustable trailing arms that are perfect. I made my panhard rod from one as well.
Regards, Ian.
OK OK! I was only trying to wind him up!
He was going to use solid bar at one point!
I knew you were joking
BTW, if anyone is interested sizes of all available RHS, CHS, and SHS can be found at http://www.channelwelders.co.uk/Products.htm
You will see as I said earlier that these are really just the thicker sections (i.e. 25 x 25 only starts at 2mm thick) What we really use is 1" square
ERW tubing (some HR some CR)
Solid Bar - I wouldn't do I thing like that!!
PS Merlin, cancel that order, ya big snitch!... Thanks for chucking in the extra tubing, I'm sure you know how much I need, can you add any extra 30mm
tube for the bush ends for the rods as well to take the MK bushes, saving me getting it elsewhere?? Don't want much do I..
