Is the a recommended toe and camber setting for a locost type car? Straight ahead??
Need to set mine up.
[Edited on 16/1/09 by Danozeman]
Don't know about recommended Dan, but I set mine to 1mm toe in . Seems to be OK handles fine with no abnormal tyre wear. If you need them I have some steering turn plates , camber and castor gauges and corner weight scales
Thanks for that mel, iv got all the alignment stuff at work. the weight gauges would be handy though.
Let me know when you want them.
Ok mate. Maybe ill pop over and show you the car and you can show me how to use them
Will be around this morning until about 1pm . Going to be away from then until tomorrow afternoon.If I'm not at home will be over the garage
Dan,
I set mine to straight ahead - a little toe-in is fine, but toe-out can make it very twitchy when you're trying to go in a straight line!
set it to parallel
set it to parallel
set it to parallel
set it to parallel
set it to parallel
set it to parallel
