Can you please post some pictures of your rear uprights. Im trying to avoid anything using a tube down the center. Has anyone got any examples using
just plate steel.
Mikkel
See a bit HERE
Fred W B
No tube used on mine, but i did use the Sierra ABS hub carriers, which was a bit of overkill. May give you an idea though. Cheers Ray
Plus one I made earlier
thats more or less the sort of things im after, what thickness plate did you use?
Mikkel
The rusty bits laying on the floor are all 3mm rolled plate. The hub mounting could be either the one from the Sierra suitably modded, or a piece of 8 or 10 mm steel. Cheers Ray
Try this link from the
Haynes Roadster Forum
http://www.haynes.co.uk/forums/showthread.php?t=1247
HTH David
I made mine from 5mm steel plate. The dimensions are more or less the same as the avon but with a few refinements
Forum Code:
Forum Code:
Forum Code:
Forum Code:
[Edited on 24/1/09 by fazerruss]
