Brakes
Pdlewis - 7/2/09 at 09:03 PM
Ive bleed my brakes today (all new pads / discs front calipers wilwoods new rear sierra almost new) and some of the wheels no longer spin freely when jacked up. The pedal is hard.
Is this normal or have i done somthing wrong. I have never setup a full new brake system before
rusty nuts - 7/2/09 at 09:17 PM
Which master cylinder(s) are you using? does it/they have an adjustable push rod? It sounds like you don't have any slack in the pushrod, if it is adjustable then shorten it .
Pdlewis - 7/2/09 at 09:21 PM
I have 2 cylinders one a .6 and the other .75 on my from one wheel spins freely the other spins by hand but stops almost as soon as you let go
Dangle_kt - 7/2/09 at 10:17 PM
bit of wd 40 on the disc?
(obviously a joke... )
mookaloid - 7/2/09 at 10:27 PM
That would do it
ReMan - 8/2/09 at 12:48 AM
I'm inclided to say nomal if were talking about a raised car and some resistnce.Should be fine once on the road
Ninehigh - 8/2/09 at 07:55 AM
While it's jacked up check that the pads aren't in contact with the disc... They could be touching although (as far as I know) that wouldn't explain the stiff pedal
iiyama - 8/2/09 at 08:26 AM
Ive got a similar issue Paul.
Pedal was soft so I bled the brakes to death, (put another 1/2 litre of fluid through!). Pedal has now firmed up, (although not as much as I would like), but something appears to be binding. Havent investigated yet but if I find something Ill let you know!
MC's are .625 front and back.
rusty nuts - 8/2/09 at 08:56 AM
Crack open the bleed nipple on the wheels that are binding. IF the wheel then rotates freely the master cylinder push rods are over adjusted.(Common problem if you do a search) If there is no change then it may just be the pads in contact with the discs and may rectify itself after the brakes have been used a few times.
