HI all,
On the home run now with the car build .
so after some suspension and brake set ups for the Mk indy , Wilwoods on the front drums on the back ,coil over shocks as standard with higher spring
rates on the front . any info to Get me through the SVA test
Tap your local MOT station and ask for brake, emissions nd headlight check without inputting on the system.
When I did it they didn't even charge me!
Good advice , and should put me in the right direction if i need to make changes .
Taa vinnie.
Put loads of piccys on here so we can pick out any little possible failure points.
