Brake Upgrade
liam.mccaffrey - 23/2/09 at 11:25 PM
Im looking for a way to search brake disc dimensions in order to make cheapo brake upgrades easier. A few years ago I did a similar thing to a QH catalogue for clutch friction and pressure plates to make matching up drive combos easier
I'd be looking for the standard bolts x PCD and maybe centre bore. Personally disc offsets are less important as I'm making custom caliper brackets anyway.
Anyone have any ideas, the QH brake catalogue doesn't have this info
liam.mccaffrey - 23/2/09 at 11:40 PM
I have messaged a few people on ebay about brake catalogues they're selling, ill keep you all posted
davidwag - 23/2/09 at 11:50 PM
Hi,
This may be useful for you, if you go into catalogue you have the option to search by dimension.
http://www.brembo.com/ENG/catalogo_AM/2008/index.html
Just found that if you search by car and click on the disc it gives fully dimensioned drawings (including weight)
[Edited on 23/2/09 by davidwag]
ReMan - 24/2/09 at 12:01 AM
Start with the 375mm disks
Then work back to reality
ReMan - 24/2/09 at 12:02 AM
alistairolsen - 24/2/09 at 12:05 AM
http://www.brakeworld.co.uk/
all the info is there, its just a pain to search
Volvorsport - 24/2/09 at 12:37 AM
330 , 302 , 287 , 280 , 265 mm in varying offsets .
5x 108 those are the volvo sizes youll ever need !
liam.mccaffrey - 24/2/09 at 08:12 AM
cool that brembo site is pretty good.
interestingly none of the drawings include the PCD of the fixing holes
