Does anyone know if the early sierras have the same rear beam as the later ones. I'm trying to build an early vindicator and nothing seems to
fit. I have already replaced the cortina front suspension with a locost version. The rear beam I have is from a 1988 sierra and none or the mounting
points line up.
Ditch the rear beam and put a dedion in instead.
The estate has a differant beam .
Hi mate sounds like you need a Cortina axel.
Buy retroford mag or go on line to find specialist ford breakers theres a few about see if they will do aswap for yours with a bit of cash.
