Golf rear calipers
AdamR - 29/3/09 at 09:11 PM
Guys... just trying to sort out my rear brakes. I was planning to go the Wilwood route, but they are expensive and the poor handbrake performance has put me off.
So... mk4 Golf calipers seem to be a good way to go and bolt straight onto the Sierra hub carriers.
Two questions:
1) How much lighter is the Golf caliper over the Sierra item?
2) Where can I get the caliper carrier from? Most places only sell the caliper body itself without the floating slider dodah. Is VW main stealer/scrappy my only option? Can't find them anywhere online.
Anyone know if Rally Design still do the Golf calipers? Can't find them on the website any longer.
tomgregory2000 - 29/3/09 at 09:12 PM
scrappy?
daniel mason - 29/3/09 at 09:50 PM
im sure the caliper is lighter but the standard discs dont fit.by the time you replace disc i think the weight is very similar. im sure someone will come along with more info than me but im sure someone said this the other day
skippad - 29/3/09 at 10:21 PM
Golf/audi/octavia (more options) are a lot lighter than sierra items.
I got mine off a 54plate Audi A3 in scrappy, i think they were low miles as they were as new.
They fit straight onto sierra uprights AND discs, even the handbrake cable is useable.
Those wanting to run 13" wheels will have to grind away some of cooling fins to
fit.
AdamR - 29/3/09 at 10:21 PM
Yeah you're right about the disc. I'd have to use the large 273mm disc as used on some of the Sierra Cosworths... but I have to use that anyway as I have the Cossie hubs.
skippad - 29/3/09 at 10:32 PM
Yes i have standard sierra 4x4 hubs/discs (not cosworth) so all fit OK.
james h - 30/3/09 at 09:33 AM
Yep just to add that if anybody uses standard rear disc hubs and carriers (i.e. not 4x4) then the disc wont sit far back enough, and the caliper is a centimetre or so too far out from the centre of disk. Easily sorted by some sort of spacer, but I haven't got round to that yet.
JAG - 30/3/09 at 09:59 AM
I've designed two castings for these aluminium rear calipers and I can tell you they are NOT cooling fins but are there to give stiffness to the casting.
Less stiffness means more flexibility which will lead to a shorter fatigue life
You have been warned
Miks15 - 30/3/09 at 10:29 AM
Sorry to steal but does anyone know what disc width and diameters these calipers will fit?
IM want to get a set but want to make sure the discs I already have (BMW)
AdamR - 30/3/09 at 01:25 PM
I'm planning to use 273mm diam solid (10mm) discs from a Sierra Cosworth. Should do the job nicely.
ghostrain - 4/4/09 at 06:08 PM
Rally Design still have some of the new Golf calipers left .
JEPY - 11/4/09 at 07:45 PM
Adam,
I've got a set including a handbrake cable for them unused that I'm now not going to use, purchased from Rallye Design.
Could do you a deal..?
James
PumaWestie - 5/5/10 at 12:40 PM
Can anyone describe how they attached the brake hoses to the Golf calipers? I am using 13" rims so space is limited for banjo bolts but the thread in teh caliper appears to be M12 x 1 which makes using an adaptor necessary to screw in a 3/8 or M10 banjo which makes the connection bulky and therefore fouls the inner of the wheel rim.
