hopefully someone has some info, im looking for dimensions for a cortina hub, just the inside bearing hole dimensions to be exact. the cortina hub in
the cad library has the outer shape but there is no hole through the middle so i dont know what size the holes the outer of the bearing needs to fit
in to, and dimensions between the two etc!
Hope someone has these dimensions
Thanks Alan
Try NTN's website and look for 4T-L44649-L44610 and 4T-LM11749-LM11710
These fit in the aluminium cortina hub supplied by Rally Design
[Edited on 6/4/09 by Mad Dave]
thanks for those, i can find the bearings but the only dimensions given are for things like maximum/minimum radiuses near bearing etc, no full outer
dimensions? There are some full outer dimensions but these are given in another table, without the code name of a bearing next to it, so it cant be
related to the ones you gave me the code for..? also i dont know how far apart the bearings should be in the rotating hub?
thanks alan
http://www.ntn.co.jp/english/products/pdf/ball/pdf/Bearing_en_b146-183
.pdf
This is the pdf i found, first bearing is two pages down, the other is 4 pages down. Inbetween, on page 1 and 3 is the info i want to know but it
doesnt have the codes beside the dimensions?
Thanks al
Thanks fella, got the dims i need
