Pedal Box Help (Brakes)
Miks15 - 7/4/09 at 03:51 PM
IM using a sierra master cylinder and following the designs of the haynes pedal box. I cant see it says anywhere about the clevis and pushrod?
Anyones got any pics of theirs?
Also does it need to be adjustable or is a solid one good enough?
Mikkel
James - 7/4/09 at 06:05 PM
Personally I went for an adjustable length push rod... just to give me a little bit of extra flexibility.
I made my own pedals, I used the clevis pin and saddle and half the rod from the Micra pedal set I was originally going to use and I welded that to end of the adjustable Sierra pushrod.
HTH,
James
James - 7/4/09 at 06:08 PM
Miks,
I just checked the book... page 108 has pics and dimensions of the rod.
James
Miks15 - 7/4/09 at 06:48 PM
Cheers james, will check it later tonight,
