Morning All,
I tried to finish off my handbrake this weekend and guess what - I have a question!
I got the clips in the picture from Ford, but I can't for the life of me see how the are supposed to secure the handbrake cable to the drum brake
backplate.
Have I got the right bits?
Any info. much appreciated.
Nick
Its a bit hard to tell from the photos but having stripped my donor sierra back end today, I`d guess those go around the fittings on the end of the
outer cable & push thru the back plate to click into place. I had sods own jobs dismantling mine, eventually filed out a washer to go over them to
compress the clips & they popped out ok. We`re lucky in NZ that these bits tend not to rust & can be reused. The amount of tinworm you Brits
have to endure is something I`m thankful to miss. Cheers Steve.
[Edited on 23/2/04 by Steve Hnz]
steve is right,put them round the end of the outer cable n push it into the hole,the large dia bit stops clip pushing all the way through the hole
I thought that might be the arrangement, but I couldn't seem to get it to fit. I'll give it another go with a bit more force.
Cheers guys
Nick
medium weight thumping impliment and blunt chisle are required
