Has anybody got a pdf on how to fit a steering wheel boss, just trying to get my head round how to wire the horn, the wheel I'm going to get has
two individual buttons was thinking of using one for main beam flash and the other for horn. Now how will I pass these wires through onto this wheel
Thanks in advance.
Rich
When i got my new boss i had to fit the horn rings out of the original sierra wheel in the new boss
I can sort of understand the horn, but how will I get the main beam through???
R
We have a similar Sparco wheel to that one with the two bottons that are both intended to be used for the horn and it comes with an adaptor that has cut out for the wires to pass through, but it does relay on the original ring and not sure how you are going to manage to split this in to two seperate features as you need both the slip rings to work the horn, but good luck if you do go for it.
Sounds like too much work, think they'll both be horns
Rich
You could have a wire like on a telephone coming out the back of the steering wheel
You want some of
this
4 core.
Chris
