Best Brake Master Cylinder?
ashg - 25/5/09 at 09:07 PM
I have the brake master cylinder from the sierra which i am meant to use for my build. what worries me is that it is a pretty large master cylinder which should have servo assistance.
what would be the best master cylinder to replace it with from a non servo assisted car? i will be running standard sierra calipers and drums.
i dont want to use dual cylinders with a bias bar before anyone suggests it
cheers
Ash
Bigheppy - 25/5/09 at 09:31 PM
This sounds good so i've bought one to try, but will be a while before I'll get a chance to try it.
link
cd.thomson - 25/5/09 at 09:37 PM
your car will be half the weight of the sierra, therefore youll only need to apply half the force to the brake pedal to still bring it to a stop in a similar distance. .
ETA I'm also trying to find a link, but im sure brake servos just about double braking force, so I'm not sure you would even perceive too much of a difference between the two setups
ETA x 2 - just read that thread, maybe im wrong
[Edited on 25/5/09 by cd.thomson]
Mark Allanson - 25/5/09 at 09:55 PM
I used the standard sierra MC on my car with M16 at the front and Capri drums at the rear, no need for a compensator, passed SVA with no problems and a pleasure to drive after 10K miles in 4 years on the road.
The non cast tubular MC will work by just removing the servo and bolting straight onto the sierra pedal box
ashg - 25/5/09 at 10:10 PM
my master cylinder is a cast one. is there something i need to do with it?
britishtrident - 26/5/09 at 07:04 AM
The a Seven style car is a lot lighter than a Sierra but there isn't enough room to get long enough pedals a decent pedal leverage ratio as a result without a servo you will have to press the pedal about 2 to 3 times harder than in the donor Sierra.
Production cars without a servo have always use a smaller bore cylinder than those with a servo ---- Caterham and Westfield both use 17mm bore master cylinders on the standard setup.
This subject is covered at least 4 times a month in the forum, if you do a search you will find lists of suitable dual circuit master cylinders from non-servoed equiped models.suggest you try the forum search.
[Edited on 26/5/09 by britishtrident]
