Where can i get a locost steering wheel that is smaller that my current one?
I dont mine using the one i have but when i take my foot of the clutch, it hits the bottom of the wheel.
i found mine on ebay... just keep looking around
But would just any wheel fit?
Is it your foot or the clutch that hits the wheel?
Originally posted by Richard Quinn
Is it your foot or the clutch that hits the wheel?![]()
if you are using the sierra column you will need a sierra boss that is compatible with the wheel. alternatively if you are not using a sierra column
you need the corresponding boss for whatever column you are using
HTH's
Alex
make sure that your boss and steering wheel are compatible aswell.
Its the original Jag column.
A smaller wheel will make manoevering at low speed much harder if you have a heavy engine
