I know it has something to do with rotating one wheel and if the other one turns, doesn't turn, and what direction or something etc but I'm
a little light on the details.
I'm sure everyone knows this one but me.
If you turn one and the other turns the same way it's an LSD. If it turns the other way it;s not. Or something.
dip the clutch on a corner with full throttle. If the inside wheel spins, its an open diff. If you end up backwards in a ditch, it was an lsd.
If it's a sierra diff then if it is very stiff to turn a wheel when it's off the ground then it's a LSD. If the wheel spins freely
it's open.
Don't rely on the turning one way or another thing to try and work it out as both types work exactly the same way.
Mark
Or as Joel says
Originally posted by JoelP
dip the clutch on a corner with full throttle. If the inside wheel spins, its an open diff. If you end up backwards in a ditch, it was an lsd.![]()
as mentioned before, when the wheels are up off the ground, and turned by hand, a LSD will act the same as an open one in as fart as the direction the wheels turn, ie the other wheel will turn the opposite way to that which you are turning your wheel, as ive worried about that before and asked about it.
No
I have a LSD fitted and i can confirm that when both wheels are off the ground and you turn one of them the other rotates in the same direction of travel.
I also like the "garden" test, where you do a burnout on the grass as you save your tyres and get a #11 proving you have an LSD
No
Is it possible that mark and hellbent are talking about an ATB diff like a quaiffe, which i believe would act like an open diff when you turn a wheel by hand, as opposed to a sierra viscous diff (or is it a plate diff?) which is exactly as you say, that both wheels will turn the same way?
Just a thought![]()
[Edited on 29/5/09 by JoelP]
Just to confuse you even more aerosam, wether the pinion flange that the propshaft bolts to is stationary or not makes a "Diff"erence.
When testing an LSD, both wheels will turn opposites if this flange isnt held still. If it is held still, they will turn the same way.
When testing an open diff, this doesnt make any difference.
Am i wrong anyone?
Originally posted by MakeEverything
Am i wrong anyone?
