I have let my dad have the Tiger for the time being. He wants to use it for dry weather cruising through the mountains of North Wales. He wants me to
find him a second set of wheels and tyres for the car (Currently fitted with 14" Yoko AO-48R's)
I'm looking for some 185x55x14 tyres that won't break the bank, but won't be a complete liability.
I've found a few, any opinons anyone:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=390028819033
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=170337927981
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=120426021403
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=360158965331
For unspirited driving - whats up with leaving the Yoko's on if its for dry weather? He's not likely to be wearing them out drivng gently but even if they do wear a little - its a lot cheaper than a complete set of wheels and tyres
I think he doesn't want to wear out my track day tyres, but in the same breath thinks the Yokos look a little 'bald' for road use. The cost of a set of second hand alloys won't come to more than £60 (not worried about condition) and to be honest if he's happier with a more conventional set of tyres, I'm not bothered about spending out on some reasonable ones if it makes him more comfortable with the car.
Gotcha - fair enough then. Well to be honest you might like to consider moving up to a 15" rim then due to the potential bigger selection of
tyres. If you fancy using them yourself also then have you considered going somewhere inbetween the "cheap" tintop tyres and R888's?
How about a set of these??
http://www.camskill.co.uk/products.php?plid=m4b580s99p7558
A lot of sprinters use them especially in the Westie Speed series (I thought they did anyway although looks like Toyo sponsor the series now) as they
are list 1b (i think thats the right "list" - its a while since i did a sprint). They might wear out before perishing unlike the tyres you
listed but are cheap enough still
Just an option you might like to consider. There seems to be a few mentions of them if you do a search on here
[Edited on 1/6/09 by Steve G]
No really thoughts on tyres (only just learning) but you can pick up a set of 13*6 ford laser for £30 if you wait a week or so on ebay.
Daniel
Now that looks like a plan, thanks for the link.
The change in diameter is small too
185x55x14 = 22.01"
195x50x15 = 22.68"
Thanks dhutch for the heads up, but 13's may be a little tight over my sierra xr4x4 calipers
No problem at all - they are a good tyre for a lightweight seven type car and have a few recommendations by the looks of it.
http://www.locostbuilders.co.uk/viewthread.php?tid=108903&page=&contribmessage=none
Just wouldnt want to see your car spinning off the road due to unsuitably hard tyres.
get a cheep set of 15's and some of these
click
That was my worry Steve - the tyres being too hard.
Just been off on ebay to source a suitable set of 15" rims. Looks like I should be able to get some fairly cheap. I reckon I can do the whole job
for under £200, and like you say they might be OK for me to drive on too, maybe even on a track day.
I havent looked myself but would think a set of ET38 15" alloys would be easier to find anyway, as well as offering a better selection of
available tyres such as the T1-Rs mentioned above which is another quality tyre. The Marangoni's are softer and so probably wear quicker than the
T1-R's but should offer extra grip.
Would be interesting to hear from someone who has driven them both - i have only used the older T1-s against the Marangoni's myself and found a
decent improvement with the Marangonis. I know the T1-R is grippier than the T1-S too though
Shame your not closer, I have five fourteen inch Ford alloys, with vertually brand new 195 x 60 tyres, (done 800 miles). Have a look in my archive in the "For sale" bit, £100 ono. Cheers Ray
i like the sound of that.... i was on t1s, and now just put 4 new t1r's on![]()
I run semis for track and Falkens for commuting to work. I used to use the ZE512s but they were recently replaced by ZE912s. They have a soft side
wall which is good for driving on our potted roads!
The ZE512s were actually a laugh on track too as you could easily and progressively slide the car around at modest speeds.
Other than that I wanted to run Kumho KU31s but couldn't get a fitment or I use Toyo CR1s on my tin tops and Toyo confirmed to me via email they
were OK for a light kit car.
As above though go for 15" wheels for general driving as you get a better selection.
