I have two questions about an axle i am planning to buy;
1) The axle is from a MK1 Escort 1300, what ratio is the diff likely to be?
2) what is the standard diameter of the Escort axles? (to allow me to make the mounting brackets)
Any help appreciated.
I think you'll find the attached useful. Applicable to MK1 also.
Rob
Cheers for the attachment, if the MK1 and MK2 are the same the diff should hopefully be a 3.89 (which is what i am wanting).
You can always count the teeth if still unsure!
